Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fabricate right exhaust pipe & heat muff 3 of 4
Now the manifold is removed and the exhaust pipe is placed in position to transfer the cut line to it.
Cut the pipe to the line and test fit to the manifold and mark for tacking on the bench.
I broke the tacks and rotated the fit up .06" to provide better clearance.
Pipe through plane
Draw line around pipe
Tacked in position
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
