Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fabricate right exhaust pipe & heat muff 2 of 4
Cut the manifold .5" from the stub to establish the cut plane.
Clamped a piece of sheet metal to the engine mount, flush the end of the manifold.
The cut plane will get removed and replaced several times here so it is important to mark it so it can be relocated exactly where it was.
Transfer outling of manifold onto the cut plane, and cut it out.
Establish cut plane
other side of cut plane
exhaust manifold cut plane
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
