Brief Description: Fabricate right exhaust pipe & heat muff 1 of 4
The right side gets the heat muff, WW gave me a couple of end pieces that get welded to the tube that make up the heat muff. I just clamped angles to them to see the box shape and to make it as long as I can, it get cold up here.
Now the trick is to establish a cut line on the bend that mates with the exhaust manifold.
