Ron Lendon's Aircraft Mfg.
Date:  3-19-2011
Number of Hours:  7.00
Brief Description:  On its gear finally
Finished up mounting the nose wheel fork and front tire. Made a few runs to the aircraft hardware store.
Next it wass clean off the table and raise the fuselage so we could pull the table out and move it to the back patio.
Had the fuselage supported on saw horses, closer to the ground and attached both the nose wheel and main gear. The set it down off the horses and it was a tail dragger for a little while.
Mounted the engine mount and engine and that brought the nose wheel to the ground.
It just fits. Now its time to rearange the garage and get the motorcycle back home.
