Brief Description: Reverse some rivets and test bend nose gear
Removed and replaced the rivets around the cross bar so the heads are on the inside of the chanel. I thought the bungee was to close to the shop heads.
Tried a test bend for making the nose fork and doubler, not so easy. It's worth the money to purchase so I did.
I might be able to do this with hard wood, the 2 x 4's broke up but I was able to get a 90 degree bend in both pieces. By the time I got all the correct materials to make the tools and do the machining and welding it just made more sense to spend the $100 and get the pieces from zenith,
