Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Nose gear lower bearing
Drilled and tapped the holes for the bottom of the bearing blocks.
Set everything back up on the mill and enlarged the hole for the tube .010"
Clamped and bolted it back to the fuselage and now it has no friction.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
