Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Little bit of fab and a lot of welding
Fabricated .050" end cap to keep bungee in place.
Drilled the cross tube for the pedals.
Welded bottom plate.
Welded pedal tube at 10 degrees.
Welded bungee stop plate and tube.
Tested to fit with the bungee in place. Looks like I might want to reverse some of the rivets for more clearance of the bungee.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
