Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Cross drilling Nose Gear down tube
Squared up the best end for the bottom and trimmed the other with tube cutter.
Layout holes and drill on the mill. Used 3/4" end mill for final sizing.
Rotate 90 degrees and bring back to level with vee blocks on the cross tube and the level on top of them.
Ready for end cap, bolt holes in the cross piece and welding.
Square up end and size length
Same angle as the vice
Cross drilling done
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
