Ron Lendon's Aircraft Mfg.
Date:  1-26-2011
Number of Hours:  1.00
Brief Description:  Flap torque arm install 1 of
Cleaned up all tools and rotated fuselage off the bench to gain access through the bottom door.
Set torque arm up on the bench and marked the alignment. It's from a crashed airplane but no damage to it. If the length and angles are right its a keeper.
Checked the dimension of the hole in the fuselage and had to move it 1/8" back
