Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Arm rest & Flap Torque Tube
Test fit with clecoes and I can get it in and out so the top arm rest gets riveted.
Had to cut the bolts out on the upper outside of the center spar. The bolts at the top outside must go in from the front.
Had to reset the wing jigs and mark the hole centers to the flap torque tube.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
