Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Seat back Chanel & forward torque tube bearing
Layout the rivet lines for the two L-Angles on each side of the center seat back channel.
Tightened up the bends to fit inside the verticle angles. Poke torque tube hole in bearing bracket and trim end angles.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
