Ron Lendon's Aircraft Mfg.
Date:  1-8-2011
Brief Description:  Caulk, rivet front side skins and firewall 1 of 3
Opened up the clecos along the bottom of the firewall and ran a 1/16" bead of high temp red RTV. Bolted and riveted the bottom of the firewall.
Opened the left side and deburred and caulked it and the fresh air box also. Put all the clecos back in to hold things together. Riveted left side in place.
Added corner gussets 6B15-2&3 on the left side.
Prepped right side and followed the same procedure.
Bottom firewall
Bottom firewall
Left side forward skin
All the clecoes
All the clecoes
