Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Set center spar rear wing attachment uprights
Opened clearance holes in the wing jig to transfer the hole centers to the wing attachment uprights.
Reset center spar jig and transfered hole centers to the wing attachment uprights.
Drilled rivet line along top longeron on the right side.
Drilled and riveted the 6B5-6 on the right side, stopped at the baggage shelf.
Only pilot drilled where the middle top skin attaches.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
