Ron Lendon's Aircraft Mfg.
Date:  12-25-2010
Brief Description:  Reset wing jigs and mark for transfer punch
Rechecked and adjusted setup so I can mark the outer holes in the uprights. Need to make a clearance hole in the wing jig to be able to use a transfer punch to mark the center of the holes through the uprights. Have 82 degrees on the spar not the 81 the print calls for, talked to Caleb about this at Oshkosh.
