Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Main Landing Gear Attachment
Trimmed angles, deburred and bent 5 degree bends.
Setup for welding using a thick angle plate and a steel bar to hold everything true while tacking.
Removed clamps, filet stitch welded in the inside vee then ran a bead along the out side joint.
Grind weld on the bottom surface and check squareness of the flange. Had to open it up a few degrees to get 90.
Ready for the studs.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
