Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
More fuselage work
Finish drill landing gear channel, remove and deburr, reinstall.
Validate front to rear level with laser light from both sides of fuselage.
Cut 470mm supports to seperate gear channel and upper longeron the 497 dimension.
Re checked all angles, looking good.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
