Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Cutout rear spar clearance in rear side skin
Raised rear fuselage up so I could get clecos and rivets from below.
Cut out the layout on the forward rear skins and test fit.
Positioned aft bulkhead and clecoed it in position.
Positioned middle and baggage bulkheads and clamped in place.
Need to make some L-angle to keep everything square and in-line.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
