Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Intake Fabrication
After roughing on the mill I used the cutoff wheel on the dremel tool to get closer to the line.
I placed marks on both tubes so I could align them back to the same place after cutting out the inside of the transistion piece.
Lined marks up, clamped and taped ends to purge argon inside while welding.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
