Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Intake Fabrication
Fabricated a shelf to set the carb on. It is on a parallel plane to the oil pan flange.
Trimmed ends of both left and right upper down tubes.
Trimmed the tube of the carb flange down to the transistion point.
Shelf for carb to sit on
Block carb up to height
Now we can fit the tubes
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
