Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Set rivets with squeezer in center spar
The squeezer worked much better.
Spend some time setting up with test strips then just squeezed all I could. 4 rivets must be bucked
Need to buck at the angles
Redi-Set Rivet Squeezer
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
