Ron Lendon's Aircraft Mfg.
Date:  8-23-2010
Brief Description:  Back drill center spar
With center spar assembled, I back drilled through the original and the holes are elongated. Zenith says this is OK because it is in the middle of the sandwich and the other holes (20mm spacing) are through all metal layers just like the original 40mm spacing.
Modified the bucking bar to get in the the tight location of the center spar.
Elongated holes
Elongated holes
Bucking bar
Bucking bar
Bucking bar
Bucking bar
