Bob Leffler's RV-10
Date:  5-8-2010
Brief Description:  Remote Starter Engaged Annuciator
I started the day by picking up my cabin cover and interior panel set from Geoff. Then when I got home, I started on the annuciator circuit for the starter.
The starter relay has an output pin - generally labeled "I" - that is turned on when the relay is engaged, i.e. the starter is on. The idea behind this output is that you would wire it to a light bulb on the dash and then to ground. Whenever the starter is engaged, the light will come on and warn you that the starter is currently on. Otherwise, if the relay were to become stuck you probably are not going to be able to hear it and likely damage the starter and probably the engine.
The VP-200 LCD display has the capability of configuring "Annunciator Lights" for most any condition you might want to warn yourself about. There are 16 input pins on the VP-200 system that allow you to connect a switch to ground and trigger the input. Using the Annunciator Configuration page on the VP-200, you can configure when the warning is displayed, what pin on the CU or DU that it is coming in on, and what the warning says.
All of that sounds like a perfect setup for the aforementioned Starter Warning. The problem is that the output on the starter relay is 12v when its on, and the VP-200 inputs expect to see GROUND when activated (note: there are two +12v inputs J5-11/12 but they are used for other things). So, I copied this from Matt Draille, who came up with a little logic reversing circuit that converts the 12v output from the starter relay to a connection to Ground. It uses a standard NPN small signal transistor, a couple of specific-value resistors, a small bit of project board from Radio Shack, and some heat shrink tubing
Components assembled
First time using my heat shrink labeler
Finished Product.
Finished Product.
