I'm waiting for new Z brackets from Vans so I figured I would at least prep the tank skins for when they get here. I got the ribs clecoed completely on the top side of the right wing tank and three clecoes on the bottom side so that I still have access to cleco the baffle, Z brackets and ribs together.
The left tank skin I clecoed the bottom three holes on each side of each rib and then ran out of clecos. I have more coming from Brown. I also managed to split both sides of my cradle so I get to make a new one. I need to reinforce the bottom of it and also make the opening a little wider. The leading edges and the tanks fit pretty tightly in this one and I think that is why it split.
