Today I finished the ELT bracket installation. It came out well. I used CS4-4 and LP4-4 rivets to attach it to the longerons and ran 1/8 inch aluminum bar between the Z brackets that I cut to make angle. It is very stiff and will hold the ELT securely. The antenna will run to the aft bulkhead and be mounted to sit under the tail fairing.
