Ron Web Site
Date:  4-9-2019
Number of Hours:  4.10
Manual Reference:  7-7
Brief Description:  Sealing the Tanks
Today I started out by drilling out the rivet on the filler flange. It came out well and I used the squeezer to put another rivet in its place. Then I moved on to the ribs. I 100% clecoed all the ribs to the skin except for the one just inboard of the outboard end rib. I spread sealant on that rib and put it in place. Then removed the next one inboard and did the same. Finally, I removed the end rib to give easy access for riveting. I riveted the two ribs on and then cleaned up. Both of them came out pretty good.
