Very small leak around center of fuel cap, duct tape fixed that. The access cover is leaking! The cork gasket is now rest peacfully in the Cobb county dump. Removed cover cleaned well and reinstalled using Proseal for a gasket. Did a functional check of fuel sender, works good. I will let Proseal cure for a couple of days and truy again.
