Initial fitting of the LH cowling is not going that well, as you can see in the pictures there is a big gap (up to 3/16") between the aft end of the cowl and the forward fuselage and no matter what I do I cannot seem to get the gap to close. It feels like my cowl is just too short. I've double/triple checked the position of the engine and as far as I can tell it is spot-on. I might just be left with a short cowl which means I'll have to do some fibreglassing to get it to fit. I will do some research first.
