Brief Description: Installing the rudder cables and trim cable housin
My wheel pants stil haven't arrived so it is time to start on something else in the meantime. Control rigging. I started with the rudder cables, these have to run through the fairleads and plastic bushings. This meant that the C-clips had to be removed from the plastic fairleads so they could be removed from the phenolic block. There is no other way to get the pre-made cable through. This jobs proved to be more difficult than I thought and I spent about an hour getting the clips off and then on again after installing the cables. Lastly I also installed the trim cable housing through the grommets.
