I printed the design on the plotter at work today, it looks good, so I decided to go ahead and spray glue it to the actual panel so I can start cutting out the instrument holes, bit first I re-installed the panel with the template glued on back in my Sonex to see what it will look like in the aircraft. Still very happy with the layout, I sat in the plane and made sure everything is within reach, no problems there either. This will be my panel layout.
