Michaels Sonex #145 log
Date:  6-20-2015
Number of Hours:  1.00
Manual Reference:  T01, L01, C01
Brief Description:  Installing the rudder and tail wheel push rod
First I installed the rudder today, I still had to drill small holes in the hinges for the cotter pins that hold the hinge pins in place so this was done first, then the rudder was installed.
The rudder controll cables were then permanently installed as well and finally I also installed the tail wheel push rod.
Pretty much done with the tail now. Just the trim cable left to do.
