Michaels Sonex #145 log
Date:  2-28-2015
Number of Hours:  1.50
Manual Reference:  L06
Brief Description:  Left wheel pant installation
It took me a bit of time to decide how to jack up the plane to get the wheels off in order to install the wheel pants.
In the end a couple of bricks, a 2x4 and 2 jacks did the trick.
The pictures show exactly what I did.
Once the plane was jacked up I levelled the fuselage by adjusting the tail height and then positioned the left wheel pant and drilled the 4 holes initially to 3/32.
Then the wheel pant was removed and the holes were updrilled. Finally the holes were tapped for 10-32 UNF, so was the hole in the axle. I was a bit afraid of this part as I've heard builders having lots of difficulties with this. Starting off with the correct hole size, using metal working lubricant and a sharp new tap made this an non-event.
Now I need to glass in the reinforcements before I re-install the wheel pant.
