Today looks like a better day to try and fir my wings back onto the fuselage, but first I need to check the spars actually still mate correctly. remember I took the angles off the spars, attached new blocks and drilled those on the drill press, in theory everything should still be in line but you never know, better to check this before installing them into the fuselage. As expected, everything is still in line, the pins need to be tapped in/out with a hammer but that is how it should be. Perfect, so far so good!
