Continued with final assembly. The VOR antenna needed a bit more support. Fabricated a stiffener plate for the bottom of the fuselage. Fit, drilled and riveted the plate in place. Mounted the VOR antenna which is much more firm. Finished wiring both wings to include landing/taxi lights, nav/strobe lights, transfer pumps, OAT and pitot heat. All wing wiring is complete. Finished installtion of the left wing main tank vent. Installed a check valve in the vent to act as a standby in case the main vent would get plugged.
