I sanded the previously applied slurry around the cabin top and rear turtle deck skin. I cut the expansion joint along that seem thenI applied a coat of primer. I also applied a first coat of primer to the front windscreen fiberglass fairing. Both areas required a minimal amount of glazing. After glazing application and sanding, I applied another coat of primer. Both areas look good and are complete.
