I raised the fuse yesterday to get weight off the nose gear and measure the unloaded gear deflection. I was particularly worried about interference with the bottom rear support bracket. And sure enough, there was interference. So today I began modifying the bracket and move the fasteners slightly rearward. I also worked a bit more on the upper left inlet a/c cover plate.
