I was concerned the the bottom cowl support plate might interfere with an extended nose gear leg. Now that I had the gear off the ground to install the wheel pant I checked clearance. Sure enough, the leg in its extended position interferes with the plate attachments. Easy fix. I filled in the existing attach holes and will make a new plate. Afterwards, I'll mount the attachments further aft in order to clear the gear leg angle support tubes. Also worked a bit on the lower left cowl a/c inlet cover. Just getting a finish coat and a tighter fit.
