I sanded the glazing on the cowl front. I removed the cowl and began some detail work. The rear gap on the top cowl ended up a bit too wide. I added a mixture of light cloth and cabo to extend the rear edge. The resulting addition will be slight but will make for a more uniform gap. I also did the same on the bottom cowl near the corner with the top cowl intersection. I also added a bit more to the left front of the top cowl. Lastly, the curved transition of the bottom cowl to the fuselage sits a bit proud. I added some "meat" to the inside radius of the bottom cowl. I'll eventually contour the outside down for a better transition. More cowl work to come.
