I sanded the foam blocks along the bottom right intake to match the higher baffle ramp due to the a/c compressor. After achieving an acceptable shape I used spackle putty to further shape and fill the modification.
Began installation of the oil cooler doors. Using Hartwell latches and a hidden hinge which both required modification beyond the normal plans.
