I layed up three layers of 9 oz cloth on the outside lower cowl modification. After this is set I will carve out the foam in the area on the inside that requires additional space for the a/c compressor. I'll transition the edge of the existing cowl with additional foam and make another cloth layup on the inside. Then on the finishing.
