Had a few Skybolt receptacle holes that needed to be adjusted. Marked and redrilled the holes for those receptacles. Riveted the top Skybolt receptacle brackets along the top of the upper fuselage. Then riveted the top receptacles in place. After a few adjustments all is looking very good. Applied a coat of thinned epoxy resin to the inside of the top cowl.
