I recieved two of the four seat heat wiring harnesses from Aerosport. I calculated the additional wiring necessary to assemble the harnesses. All four control switches will be located in the overhead. I ran the multiple 18 and 20 gauge wire through the A pillars to the overhead. I continue running these wires to the relays which will be located under the rear seats near the flap control mechanism.
