Most of the lights in the cabin will be dimmed through the G3X system. The only exception is the dome light. I had an older Bob Nuckoll's dimmer from a previous project and thought it might work. Well, after a lot of installation work, I hooked it up and determined that's a no go. I'm really not surprised but thought it worth a try. But I did get a lot of wire pulled. I'll order a Perihilion dimmer and be done with it.
I also cut away some of the conduit that runs along the side of the fuselage. The conduit just above the rear seat wells. That will make pulling wire from that area, to include wire coming from the wings much easier.
