Fabricated two trays for electrical equipment (fuse blocks) that will mount on hinges directly in front of the instrument panel. The rear of the trays will be attached with small Skybolt fasteners. This will allow easy access to the fuse blocks and any other equipment installed on the trays. With the exception of the fasteners, I installed the right side tray. This tray will receive four fuse blocks and one relay. I'll install the fasteners after the instrument panel and sub-panel are more securely installed primarily along the bottom.
