Rick's Web Site
Date:  8-4-2020
Number of Hours:  2.10
Brief Description:  Battery & Pitch Servo
We'll be using the EarthX battery. As a result, the battery tray needs significant modification. Removed the tray and began developing a plan for mounting the smaller battery.
Originally, I had TruTrak servos mounted. The decision, wisely as it turns out, to forgo the TruTrak path and go with Garmin. We were led to believe the mounting bracket for the TruTrak will work with the Garmin. The Garmin servo fits but the mount is not aligned with the servo. After trial mount it was determined that we need to order the Garmin mounting kit.
