Rick's Web Site
Date:  7-10-2020
Number of Hours:  0.80
Brief Description:  Fabricate Engine Mounting Bolt Covers
As I mentioned, my first attempt at carbon fiber engine mount bolt covers went well. The only problem was I made them too small. I found some larger plastic bowls and gave it another try. I tried a different technique this time. After lining the bowls with two layers of carbon I layed them directly on the carbon sheet I made the other day. The carbon sheet will make the mounting flange. It sounded like a good idea but gravity took hold and created some separation on the carbon from the now upside down bowl. The layups will work buy will need a lot of filling and sanding. At least they fit.
