Ah, working on the second door is like working on the second wing. You know what's coming and it just seem repetitive and in the case of the door a bit of a PITA. Anyway, I did a bit of cleanup on the door hing openings to better accomodate the cover plates. I then removed the right door and completed the wonderfull task of cutting down the cabin door opening to accomodate the MMC door seal. I've found it easier, albeit extremely messy, to simply sand down the lip to create the 1/4" gap. That work is done and afterwards I spent considerable time vacuuming the shop...for what good it does. I'm glad today is over. Now I just need to get rid of the itch around my neck!
