Rick's Web Site
Date:  7-4-2020
Brief Description:  Install A/C Compressor
I test mounted the a/c compressor. In order to get things to fit properly, it's a set of many shims and spacers. It took some time to get everything to line up properly. In addition, the clearances around the #2 cylinder and starter are very tight. But it's all in place and I'll document the assembly sequence since this will all have to come off before final assembly.
