Getting down toward the end. Worked on the following tasks:
1. Installed and connected the parking brake cable. 2. Began electrical test by installing a ground power source and installing one fuse at a time. 3. Finished installing the pitot/AOA/static lines to the ADHRS and G5 units. 4. Installed the two PITA seat brackets that mount on top of the gear leg assemblies. 5. Hooked up the alternate air cable to the fresh air box.
