Continued work on the right wingtip. I finished fabrication and assembly of the rear wingtip rib. I'm waiting on the phenolic blockfrom Aircraft Spruce that will capture the hinge pins. I also reinforced with flox and fiberglass the inside of the tip where I cut to allow for better alignment. I'll clean up the exterior tomorrow and complete the installation of the rear rib.
