Rick's Web Site
Date:  5-18-2013
Number of Hours:  3.10
Manual Reference:  6-17 & 18
Brief Description:  Assemble Trim Tabs
Kept working on these pesky trim tabs. Dimpled and countersunk, as appropriate, all the trim tab pieces. Riveted the control horns, end ribs and bottom of the main spars. Primed all parts. Glued the foam ribs in place and put everything aside to dry. Cut the trim tab piano hinges to inital length and mounted to the elevators.
Trim tab set aside to dry
End rib top view
End rib top view
Trim tab piano hinge
